Forums >> Revit Structure >> Technical Support >> Arch top wood truss
Wed, Jan 9, 2013 at 10:16:41 AM | Arch top wood truss
billengelbach
I am using Revit 2013 and would like to make a 2 x 4 wood truss with an arched top, shown in attachment.  I am OK modeling in place, but if I use an extrusion, I can't include the webs.  Is there a parametric family made of wood members available?  All my families are composed of steel.
Wed, Jan 9, 2013 at 10:29:04 AM | Arch top wood truss
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Why cant you include the webs if you do it with an extrusion?  Finding a GOOD parametric truss family will be nearly impossible, at least I haven't.  I usually just create my own trusses to the sizes they actually need to be.
Edited on: Wed, Jan 9, 2013 at 10:29:26 AM
Wed, Jan 9, 2013 at 1:34:25 PM | Arch top wood truss
billengelbach
Well if I try to model anything that is not a closed loop I get an error message.  Do I model separate components and group them?  I am using model in Place and sketching a path then sweep or extrusion.  Thanks for your help!
Wed, Jan 9, 2013 at 1:48:43 PM | Arch top wood truss
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can do a truss that is a closed loop, look at my attachment in my previous post.  It is done as a simple extrusion.  You do not need to use a sweep to accomplish this.  You can and if you have more than one truss SHOULD create this as a family and insert it into your project.  If you create it as a family you can still create it as one extrision or many different ones if you wish.
Wed, Jan 9, 2013 at 6:21:46 PM | Arch top wood truss
billengelbach
OK.  Should I do it as a mass family?
Thu, Jan 10, 2013 at 7:47:45 AM | Arch top wood truss
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No just a Generic Model Family
Wood Space Joist
Thu, Aug 23, 2018 at 3:28:55 PM
Wood Roof Truss Visibility
Tue, May 2, 2017 at 4:08:56 PM
Truss Double Top Chord
Sun, Aug 16, 2009 at 11:36:29 PM
WOOD ROOF TRUSSES
Tue, Oct 28, 2014 at 3:16:41 PM
Truss overhang help
Wed, May 23, 2012 at 8:32:23 AM
Page generation time: 2.6447
