Forums >> Revit Building >> Technical Support >> Bring CAD links/imports to top
Wed, Jan 9, 2013 at 10:12:00 AM | Bring CAD links/imports to top
leothelionator
Is there a way to bring an imported/linked CAD linework to the top of the Revit linework/geometry, as opposed to underneath?  I am trying to overlay imported HVAC ductwork over the architectural reflected ceiling plan for coordination purposes.
I just realized that I can import the data into an annotation symbol and paste the symbol on top of the Revit linework.  This works okay, but it is a bit tedious.  Also, you can no longer query layers or control layer visibility.  Wondering if there are any more effective methods.
Wed, Jan 9, 2013 at 10:24:18 AM | Bring CAD links/imports to top
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Change the elevation that the import was inserted at to move the import up
Wed, Jan 9, 2013 at 10:34:33 AM | Bring CAD links/imports to top
leothelionator
I just found the solution.  You simply have to click on the CAD link, go to Properties, and change Draw Layer from the default Background setting to Foreground.  Very simple!
Adjusting the associated level sounds like a good idea, but it's not really possible.  Imported CAD work does not behave like model lines where you are able to change the associated level and offset height at will.  There is an option to associate it to a level, but only during import and only if you uncheck "current view only".
Cad links
Sun, Jan 6, 2008 at 2:59:15 PM
Remove hidden CAD imports
Thu, Nov 6, 2008 at 9:32:16 AM
Can I set CAD links to default to the foreground?
Thu, Jun 23, 2016 at 4:58:31 PM
Dimensioning to CAD links in Revit - Dims deleted
Wed, Aug 7, 2013 at 2:39:01 PM
Adding Material to Families based on Cad Imports
Tue, Jun 23, 2009 at 11:37:00 AM
Page generation time: 1.9808
