14 Users Online (13 Members):
Forums >> Revit Structure >> Technical Support >> structure model disappear in the detail plan
77 Posts No Rating |
This has happened a few times --
After I create a detail plan, the structure column disappeared in that detail plan. But in the parent view, the structure elements is still there. In my memory, it sometims happens, but sometimes not. What's happening?
Is the view set to the correct discipline?
The discipline is architectural.
They will show in a plan view - not a detail view. I have not figured out why this happens... I just either add a detail component or use a floor plan call-out instead of detail.
make sure that when you create your Callout you use structructural plan rather than detail. for some reason columns will disappear on detail callouts.
I actually know this work around too-- using plan callout instead of detail callout. But the reason of it is a mystery to me for a long time.
At least I know today, it's not only me.
Linked file model missing attached detail group |
Mon, Aug 17, 2009 at 8:26:38 AM
Embedded Detail Shows in plan view, but not in the plan detail call out! |
Fri, Mar 4, 2011 at 1:37:23 PM
plan detail callout in section |
Fri, Mar 29, 2013 at 12:48:11 PM
14
SketchUp into Revit Structure 2009 |
Fri, Feb 27, 2009 at 9:51:24 AM
Detail level - arch vs structure |
Tue, Jan 20, 2009 at 9:05:50 AM
