Forums >> Revit Building >> Technical Support >> Can i create a drawing Index schedule that would update based on revisions?
Fri, Jan 4, 2013 at 1:52:45 PM | Can i create a drawing Index schedule that would update based on revisions?
mrchrisfes
I have created a drawing index that utilizes a sheet schedule with parameters added so that an "X" will appear in the schedule when a box is checked in the properties of each individual sheet.
My question is can I take the manual box checking out of the equation by somehow linking the appearance of an “X” to the appearance of a revision cloud?  When I place a revision cloud on the sheet the revision schedule updates, but can this be applied to a sheet schedule?  Here is an example of the Index I have created: example index.png
Is my question clear? For instance if A-201 is issued for both revisions and is clouded as such an "X" would show in both columns, but if A-412 is only issued for the 80% review, and is clouded as such, then only an "X" in that column, without having to check a box in the properties of the sheet.
Fri, Jan 4, 2013 at 2:38:19 PM | Can i create a drawing Index schedule that would update based on revisions?
stealthnyc
4.5 Stars: 2 Votes
This has been one of the holy grails for people using Revit but it is not possible.  The information is just not linked.  One is a property of the sheet, the other is the property of the titleblock family.  You could possibly use an add-on like BIMlink to accomplish this for you.
Fri, Jan 4, 2013 at 2:48:50 PM | Can i create a drawing Index schedule that would update based on revisions?
stealth - not quite right.
You can schedule sheets and include revisons, just not in seperate columns. (Probably could using formula's)
2017- adding mutliple revisions to sheet index
Mon, Apr 15, 2019 at 3:29:19 PM
Tracking Revisions thru the Drawing Schedule
Thu, Sep 13, 2007 at 3:08:42 AM
Revit Sheet Schedule/Title Block Family Tie In
Mon, Jun 23, 2014 at 9:47:21 AM
My revisions schedule won't go over 10 revisions
Wed, Oct 14, 2015 at 6:37:09 PM
Showing 2 Revisions in Revision Schedule
Tue, Apr 17, 2012 at 4:06:16 PM
Page generation time: 2.1014
