Forums >> Workflow & Implementation >> Hardware >> Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
Fri, Jan 4, 2013 at 11:10:05 AM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
j0ker007
Hey
Im looking to building a new HP rendering power horse Workstation.  Im sortof interested in the new Revit option for
GPU rendering and also using the Video card for 3Ds max design 2013.  So has any tested the different versions of
Quadro cards for Revit 2013 in GPU rendering?  Only looking at 2000, 4000 and 6000 Quadro cards.  We have a few
workstations here that has 2000 and 4000 cards but I havent used 6000 quadro cards and I just need to know if its going
to be over kill for GPU rendering in Revit.
Wed, Feb 6, 2013 at 2:35:17 PM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
andy777bennett
maybe I am behind the curve, but GPU rendering in revit!? WHAT?!?! can you please point me to this "new Revit option for GPU rendering" because I feel like a lot of people could reallllllllly use this. Especially my SLI rig at home ;-)
Wed, Feb 6, 2013 at 3:25:33 PM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
SLI has no affect on GPU Rendering. Revit does not GPU Render either. 3ds Max iRay, Vray RT and Octane Render all do. If you have large complex scenes you will need a large memory GPU like the 6000 or a Tesla as you have to load the entire scene onto the card and are limited to the capacity of the smallest memory used card used.
i have Geforce GTX 660 ti GPUs at home and they scream on Octane Render
Wed, Feb 6, 2013 at 3:54:03 PM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
andy777bennett
that is kind of what I thought he was saying... I have never used any rendering software that utalized the GPU. So it is all about the memory? How much memory is on your 660? I am guessing that my 768mb gtx 460's would not stand up then.
Wed, Feb 6, 2013 at 4:14:56 PM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
alabaster2513
3.5 Stars: 25 Votes
scene size is related to memory. if you do fairly small scenes within max a couple 460s would do decent. that gives you 660+ stream processors rendering at once. Another important thing with geforce cards and rendering is keeping them cool, they get pretty hot so lots of cooling is vital. if you invest in something larger like my 660 youll boost your cores. mine is currently almost 3000 processors if i remember correctly.
Wed, Feb 6, 2013 at 5:58:52 PM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
j0ker007
yea my opps.  I thought it was the GPU rendering but I did a test the other day and when I did that rendering my CPU went to the max and the video card really didnt do anything but again my intel 2700k crashed on the revit demo file.
Thu, Feb 7, 2013 at 8:08:07 AM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
andy777bennett
so if I were to ever render with GPU rendering software, should I have my cards in SLI or not? And yea, even with the slight overclock they are mad cool. I have a 230mm 150cfm fan intake right on them for gaming :-D
Thu, Feb 7, 2013 at 11:14:29 AM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
alabaster2513
3.5 Stars: 25 Votes
SLI does not help gpu render. you can just disable the SLI in the Nvidia control panel i believe. my current machine has a quadro 600 for my touchscreen and max viewports and i use the 660 TIs when rendering. my box gets insanely hot though when rendering, i dont expect my geforce cards to last long
Thu, Feb 7, 2013 at 11:50:46 AM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
andy777bennett
so disabling SLI would just make each card do a different portion of the work and be more efficent than SLI?
if you learn to overclock and your cards are at stock speeds you can most likly undervolt them and tell the fan speeds to be faster for cooler temps. What case do you have?
Mon, Feb 11, 2013 at 10:57:08 AM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
alabaster2513
3.5 Stars: 25 Votes
if i remember correctly with iray and vray rt if you SLI it will only read one card, search jeff patton iray, i think he had a blog about it. i had overclocked my 560ti quite nicely but have not had the need with my 660ti, i will have to research how to use the msi afterburner on it since i currently only use it for the fan control. i have a cheap antec case but over the weekend added a 120mm fan to the side of the case aimed at the gpu and now my idle temps are 30 degrees celsius.
Wed, Apr 10, 2013 at 10:17:50 AM | Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
#11
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Would any of you guys be interested in starting a Kickstarter.com project creating a super GPU expansion box with me?
No, seriously would anyone contribute?  Then we could settle the GPU argument once and for all.  Winking
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Revit to 3dsMax for GPU utilization
Fri, Dec 21, 2012 at 12:12:35 PM
Autodesk 360 Rendering - Adjust Exposure Problem
Tue, Mar 26, 2013 at 9:43:21 AM
GTX 660 or GTX 660 ti
Fri, Feb 8, 2013 at 10:11:14 AM
Revit 2013 Raytrace
Fri, Jan 25, 2013 at 12:01:05 PM
GPU acceleration for Revit
Thu, Apr 11, 2013 at 5:49:15 PM
Page generation time: 1.5552
