Forums >> Community >> Newbies >> deleating doors from project and tagging problems
Fri, Jan 4, 2013 at 9:42:43 AM | deleating doors from project and tagging problems
Dozing
I am tagging doors in a  project with the "tag all not tagged" feature.  It's a great feature, but there have been about 50 doors deleated during the design development stage.  So, now when I tag the doors, instead of getting a door schedule in sequential order, I end up getting numbers which are skipped.  There are 100 doors in the project and the door numbers go up to 150.  I can manually change the door marks, but I think there's a better way....any suggestions???
Fri, Jan 4, 2013 at 9:59:17 AM | deleating doors from project and tagging problems
I manually renumber from a schedule if I just have to close gaps.  If you want a logical progressive number like clockwise on a plan, then you will want to do it from a plan view.  Otherwise you can find some add-on packages that help with this.
Avetech had one but I don't see their site.  Here is one that is in a similar thread:
http://www.caddaddy.com/software/revit
Search the threads for renumber to find more similar posts and possible other add-ins.
Edited on: Fri, Jan 4, 2013 at 9:59:58 AM
Fri, Jan 4, 2013 at 10:20:14 AM | deleating doors from project and tagging problems
Dozing
Since I'm assuming no final design has the same amount of doors/elements as the initial proposed design, this issue may be something future versions of Revit will hopefully address...
Fri, Jan 4, 2013 at 10:29:45 AM | deleating doors from project and tagging problems
This is not really a Revit issue.... you can deal with this as a user.
Fri, Jan 4, 2013 at 1:22:12 PM | deleating doors from project and tagging problems
CDWdavid
5 Stars: 5 Votes
The way I usually did was turn the door tag off when I placed them.
At the point when I needed to see the door schedule, I tagged all doors.
On the plan view, I manually changed all tags to a logical progressive number.
The door schedule will automatically show the new numbers.
I wish Revit can create a way such as asking the user to click the doors sequentially; then the door tags will be re-numbered by the program, instead manually modify each tag.
Fri, Jan 4, 2013 at 1:36:42 PM | deleating doors from project and tagging problems
Dozing
Thanks CDWdavid.  That's a good suggestion to get around this issue.
Revit is awesome, but some of those tasks that were once straight forward seem to have become more complicated.  I guess that's the nature of the beast when designing software to accomodate huge complex projects.
Thanks again.
Thu, Dec 4, 2014 at 2:04:10 AM | deleating doors from project and tagging problems
jakearlington
Well, that is a good idea, you will be able to define and organize each of them.
chekc my architectural design at http://caldwells.com/exterior-doors/front-doors
Tagging In-Place Families:
Wed, Oct 10, 2007 at 7:20:25 PM
it's tagging existing doors
Mon, Apr 2, 2007 at 1:50:43 PM
Problems tagging wainscottting wall sweeps
Wed, Jun 20, 2012 at 2:34:37 PM
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:11 PM
Tagging Doors from a Linked File
Wed, Apr 12, 2017 at 7:19:53 PM
Page generation time: 1.4928
