Forums >> Revit Building >> Technical Support >> Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:17:32 AM | Combining Room Schedules and Area Schedules into one Large Schedule
alexsharum
Hello,
As the title states I'm trying to combine Room Schedules and Area Schedules into one large schedule. I am not sure if this possible. I have tried some of the things I know and haven't come up with a solution. I was wondering if you guys had any solutions to this. Essentially what the owner wants us to do is calculate the area of one large room and then break out each room within that large room. I'm using Revit 2012. Thanks for your help.
Thu, Jan 3, 2013 at 10:35:05 AM | Combining Room Schedules and Area Schedules into one Large Schedule
I don't see any way to combine these two schedules.
You could do this with two room schedules placed together to look as one by using design options.
  1. Create your floor plan with all seperate (smaller rooms).
  2. Create a seperate design option that only has room seperation lines defining the larger areas.
  3. Create your normal room schedule and a seperate DO schedule.
Thu, Jan 3, 2013 at 10:57:33 AM | Combining Room Schedules and Area Schedules into one Large Schedule
alexsharum
Thanks, WWHUB I appreciate it. I will give that a shot and see if it works for me.
Large number of schedules
Mon, Jun 20, 2011 at 12:56:18 PM
Area Schedules and Area Schemes - Revit 2019
Tue, Apr 2, 2019 at 7:41:56 AM
Automate Room Equipment Schedules.
Fri, Mar 22, 2019 at 4:24:12 AM
2 different Area Schedules on same project
Fri, Aug 4, 2017 at 12:41:21 PM
schedules show up on sheets too large?
Fri, Apr 21, 2006 at 6:09:20 PM
Page generation time: 0.3551
