16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Unwanted Large-Scale Material Banding Effect in Renders
9 Posts No Rating |
Hola -
Anyone have any smart tricks to beat the typical visual banding that happens when you render a large monolithic surface (e.g. brick, concrete) in Revit? In 3ds Max, I might apply/tile in a large noise modifier with offsets, but thus far in Revit, even tweaking the procedurals in material editing and replacing the bump bitmap with a noise map, I can't beat this beast. Any bright ideas, without having to fiddle and alter in Photoshop post-work? See attached (brick masses of backgrounded structures) as example.
Is that an OOTB Revit material? I normally like to make my own materials to try and get rid of this problem. I don't believe there is any "trick" for rendering that will help with this material.
The problem is the material sample size and its uniformity. Use a different, more uniform material for these types of views.
9 Posts No Rating |
Thanks to both of you. I used an OOTB non-uniform brick, so I imagine I'm seeing the same variation repeated over and over, versus a smoother continuum that tiles more seamlessly. Much appreciated!
How to add brick banding below render? |
Tue, Jul 23, 2013 at 8:40:10 AM
Annotations too large |
Wed, Jun 2, 2010 at 8:37:40 AM
Same material renders different colour on floor to wall |
Wed, Apr 22, 2015 at 9:12:51 AM
Revit Crashes when changing Material Scale |
Sun, Apr 3, 2011 at 4:36:13 AM
Large scale projects with repeating rooms grouped... |
Wed, Jul 25, 2007 at 8:48:42 AM
