Forums >> Revit Building >> Technical Support >> Printing settings
Sun, Jan 22, 2006 at 9:06:25 PM | Printing settings
carlosgt
I noticed that the printing window in Revit is different that Autocad. Can someone tell me what are the best settings for print out a drawing in revit? Thanks.
Sun, Jan 22, 2006 at 10:19:26 PM | RE: Printing settings
eldados
eldados Avatar
4.5 Stars: 8 Votes
nothing in particular, print settings are more to do with the paper size output and can be transferred between projects. you can set it in your template and take it across to any new project. all you need to do is choose your printer and the paper size.
Integrator
KarelCAD
Perspectives not printing properly
Sun, Jan 22, 2006 at 10:22:48 PM
Printing changes annotations on sheets
Thu, Sep 15, 2016 at 6:55:41 AM
Existing Walls Printing Black (SHOULD BE GRAY)
Tue, Mar 27, 2007 at 12:42:28 PM
Perspectives printing all grayed out!!!
Tue, Mar 18, 2014 at 2:42:54 PM
Need help with visibility/printing settings
Thu, Nov 26, 2015 at 5:23:53 PM
Page generation time: 2.4224
