13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Detailing
2 Posts No Rating |
Is it possible to insert a family onto a detail view? I have a roof framing plan of which I have created some simple truss profile families showing the truss outlines so that they could be identified in building sections. Now I am detailing the roof framing plan and would like to "detail or elevate" the truss profiles to show the required bearing points and bottom chord/ceiling slopes. Would like to use the profiles/families already created if possible, but not able to figure out how to get them on a sheet.
Any suggestions?
If they are in the project, then use a "real" model view.
Could you use a legend component?
You can always export to CAD and import.
2 Posts No Rating |
Thanks WWHub - the legend worked. I creating the legend - placing the family on the legend and then placed the legend on the sheet. I am assuming that is what you ment w/ legend component.
Brick detailing - how to? |
Mon, Sep 5, 2011 at 8:31:17 AM
Detailing in Revit |
Wed, Nov 11, 2009 at 11:59:30 AM
Detailing & Anotating in a view. Can you lock the 3D elements before you start |
Mon, Sep 16, 2013 at 1:23:28 PM
Common Detailing Practice |
Fri, Jan 26, 2007 at 3:20:11 PM
Live Vs Dead detailing |
Tue, Mar 29, 2016 at 7:57:55 AM
