14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Beam system not sitting on beam
I am not really familiary with beam systems so I may be missing something. I created a beam system for concrete plank that will be spanning from wall to steel beam. I sketched the outline to exatly where I wanted it and it lines up perfectly on the wall side but I drew it to the center of the beam becuase I want it to sit on top and it will not overlap the beam! It stops short by 1/2" from the outside of the flange. I know I can change that and 1/2" would be fine if it was 1/2" from the center (like I drew it) instead of from the face of the flange. Is there a way to tell the beam system to overlap the beam without actually changing the start/end extensions of each individual plank? See attachement for visual.
Edited on: Thu, Jan 3, 2013 at 11:40:00 AM
***BUMP***
Precast Beam System not sitting on beam |
Thu, Jan 10, 2013 at 11:45:48 AM
Beam Systems not sitting on walls #2 |
Fri, Aug 1, 2025 at 9:36:25 AM
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
beam system |
Thu, Oct 15, 2015 at 7:32:17 AM
Beam & Beam systems |
Tue, Oct 21, 2008 at 4:36:54 PM
