16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Applying changes in grid to all views
9 Posts No Rating |
Hello all,
I done some grids in a level and aligned it (like draging head, changing head direction). Then I have created some more levels. And I gone to elevation and draged(extended) the grids to all levels. So I can see the grids in all level plans. But the problem is, alignment (changes) made in intial levels are not showing in other levels. I hope there should be an option to make grids in every level looks same. Or need to change each by my own??? (grids are in 3D extent)
Thank u.
If you move a grid head in 3D - this grid moves in all views where the grid is still set to 3D. @d esttings allow adjustment for single views.
Also, if grid jeads are aligned and locked to other heads, they will all move together.
Learn to set all of your grids in 3D initially at the best location for all main views then adjust the 2D in special views. You can also learn to use a scope box.
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2654-Tools_an2654/2849-Datum...
Things like elbows in grids (as shown in the OP's attachment) do not update automatically in other views, not even if the settings of the grids are for 3d, nor with scope boxes.
To transfer the same appearance to other views, select all your grids > Propagate Extents > select the views where you want to "copy" the same appearance.
Edited on: Sat, Dec 29, 2012 at 4:24:42 PM
Planta1 Revit Online Consulting | info@planta1.com |
9 Posts No Rating |
I didn't know Scope box becoz I'm new to revit. I am trying to know now. But Propagate datum extends works perfectly.
Thank u very much alfmidedina and WWHub.
Grid Dimension shown views |
Wed, Jul 22, 2009 at 8:29:13 AM
Different Grid Bubble for different scale views? |
Thu, Dec 12, 2013 at 5:42:13 AM
Grid Partial Visibility |
Wed, Aug 3, 2016 at 1:08:39 PM
Strech Grid Lines Between Views? |
Tue, Oct 5, 2010 at 3:56:32 PM
How to print Window Grid? |
Thu, Sep 6, 2007 at 11:09:55 AM
