Forums >> Revit Building >> Tips & Tricks >> 3 Wall connection
Tue, Dec 25, 2012 at 10:21:29 PM | 3 Wall connection
lds0127
Hello,
I am new in Revit and testing one of my project in revit.
I made 2 wall type (foundation 550mm and foundation 600mm)
foundation 550mm - concrete 550mm
foundation 600mm - concrete 550m m+ wall cavity and GWB
When I encountered with this 3 wall joint (first image)
If I fillet A and B and then A and C will makes error saying wall overlapped. (second image)
If I fillet A and C and then extend B to the edge of C will make small gap between A and B.(third image)
Can anyone help me how to fix this?
Thank you.
Edited on: Tue, Dec 25, 2012 at 10:22:56 PM
Wed, Dec 26, 2012 at 6:45:31 AM | 3 Wall connection
Your problems may be caused by not understanding layer priorities.  Read your HELP on wall layers.
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2654-Tools_an2654/2908-Compo...
Wed, Dec 26, 2012 at 9:20:38 PM | 3 Wall connection
lds0127
Thank you for your comment.
layer property seems right on my model.
instead, I found small sign that I can click at the end of wall C.
if you see image below, you will see small "T" shape marked with red circle.
When mouse over, it says "allow join".
I dont know what is this mean, but after I click this, filet works fine. (see second image and third image)
it is all good now.
Can anyone tell me what is "allow join" icon?
Thank you.
Thu, Dec 27, 2012 at 6:58:25 AM | 3 Wall connection
At some time, you picked disallow join - the default of all walls is allow join.  Click on any wall and right click on the dot at the end and you will see the dis-allow - allow join options.
Tue, Jan 15, 2013 at 10:03:06 AM | 3 Wall connection
jmagruder
2.5 Stars: 3 Votes
First trim wall A to wall C then use trim/extend and pick wall A then pick wall B.
This will extend wall B to A and C to make a clean connection.
The connection between wall and floor
Fri, May 14, 2010 at 8:43:26 AM
Alternative to a VPN connection for worksharing - Faster remote connection
Tue, Oct 12, 2010 at 8:51:02 AM
2011 conduit connection
Thu, Jun 10, 2010 at 1:15:54 PM
Wall Connection Issue
Thu, Jul 11, 2013 at 12:00:25 PM
Problem about wall wrap and wall connection
Wed, May 5, 2010 at 7:46:44 AM
Page generation time: 1.9211
