15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> View range in an elevation
1 Posts No Rating |
Hello everybody,
I have problems with the elevations it shows like a section.
I've tried to fit that moving the "elevation marker" and changing the "far clip plane" but it doesn't work. The elevation views still seem to be inside the building.
How can I solve it?
When you click on the tip of your elevation there should be a blue line. This line shows where the elevation is being shown from, if this line is inside your building then it will cut like a section. Move it outside your building.
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
View Range |
Thu, Oct 24, 2013 at 2:37:43 PM
component above view range not showing up in plan |
Thu, Oct 30, 2008 at 4:27:11 PM
view range |
Wed, Nov 16, 2011 at 1:59:56 PM
view range |
Wed, Jan 4, 2012 at 12:54:53 PM
