Forums >> Revit Building >> Technical Support >> Working with Linked Model
Thu, Dec 13, 2012 at 11:31:37 AM | Working with Linked Model
zachgessler
Im working with a linked model for the first time creating concrete lift drawings and also just getting back into Revit after 2 years.
Im running into a few issues. Is there anyway to edit the model itself to add more information for schedules and such? If not is it possible to copy monitor or something similar and then add the information?
Fri, Dec 14, 2012 at 4:04:02 AM | Working with Linked Model
ronmalit
5 Stars: 3 Votes
"Is there anyway to edit the model itself to add more information for schedules and such?" --yes here in revitcity, theres always a way lol. you can edit the link file and update the link on the main file? or bind the link and re-link? or open two revit session to do the updates and so on..
** dont be mad, i dont have much... i am homeless
Fri, Dec 14, 2012 at 10:14:10 AM | Working with Linked Model
If the linked file is a consultants and will change, then you really don't want to edit it.
If these are elements you can copy monitor, then that is a better process.
Edited on: Fri, Dec 14, 2012 at 10:14:46 AM
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:37 AM
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:28 PM
Linked Model - Losing only some doors from linked model
Thu, Oct 21, 2010 at 1:52:14 PM
Moving a linked Revit model
Thu, Nov 21, 2013 at 3:57:59 PM
Linked model view setting not working
Thu, Jan 10, 2013 at 1:17:23 PM
Page generation time: 0.6543
