Forums >> Revit Building >> Technical Support >> Doing a Frit in Revit
Tue, Dec 11, 2012 at 11:02:23 PM | Doing a Frit in Revit
janonliu
HI Guy's trying to do a frit pattern but having problems.
Whats the best way to do it? I drew the pattern out on CAD and then PDF'ed it, then took it into photoshop and created a
300mm X 4045mm strip, for the cutout. the cutout doesn't seem to work properly.
So I have a layer for glass and a separate layer for the frit, but the frit seems to come up solid. at the top, where
there should be nothingas the frit is meant to fade away.
Maybe there is an easier way to do this? Not great at photoshop and my image is a bit burry.
Thanks
Jan
Wed, Dec 12, 2012 at 5:46:11 PM | Doing a Frit in Revit
quinn
You need to attach the jpeg for the cutout.
Wed, Dec 12, 2012 at 6:13:32 PM | Doing a Frit in Revit
janonliu
I added the Jpeg to the cutout, part, but it doesn't seem to be transparent at the top.
Thu, Dec 13, 2012 at 9:55:52 AM | Doing a Frit in Revit
quinn
Cant tell where the issue is unless we have the jpeg image for the family.   Remember black is cut white remains.
Curtain Panel Glazing with Frit
Mon, Jul 23, 2007 at 5:04:08 PM
Cutout looks fuzzy
Wed, Jan 16, 2013 at 12:01:37 AM
Rendering glass with pattern 2009
Mon, Oct 13, 2008 at 3:27:21 PM
Splitting the face of a curtain wall?
Tue, Apr 27, 2010 at 1:19:53 PM
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
Page generation time: 2.8562
