Forums >> Community >> The Studio >> Switch from revit 2011 to revit 2013
Sun, Dec 9, 2012 at 11:36:03 AM | Switch from revit 2011 to revit 2013
troysmithfreak
4 Stars: 11 Votes
Hi guys, so i am a highschool student and we use revit 2011 at school and that is what i use at home. Its the only version ive ever used and over the holiday break we are switching to 2013. what changes should i be expecting? thanks.
Mon, Dec 10, 2012 at 4:02:51 AM | Switch from revit 2011 to revit 2013
4 Stars: 205 Votes
Check here: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00002-New_in_Revit_2013
Mon, Dec 10, 2012 at 7:24:57 AM | Switch from revit 2011 to revit 2013
Also realize that Revit is not backwards compatable.  That means you can do something at home in 2011 and work on it then at scholl, but once it is in 2013, you can no longer work on it in 2011.
Is there a way to show switch circuits in Revit MEP 2011
Thu, Mar 17, 2011 at 5:17:45 PM
Switch ID Grayed out in Revit MEP
Tue, Feb 26, 2013 at 11:33:36 AM
Revit 2013 exporting into Autocad 2011
Sat, Aug 4, 2012 at 11:06:34 AM
I can't assign a switch ID to a switch
Wed, Dec 9, 2020 at 5:42:46 PM
Making the switch from Autocad Arch to Revit today
Thu, Apr 11, 2013 at 2:17:30 PM
Page generation time: 2.6686
