Forums >> Revit Structure >> Technical Support >> Section marks appearing on plans
Thu, Dec 6, 2012 at 3:42:05 AM | Section marks appearing on plans
mcinthepeaks
Hi,
Can anyone give me some advice on how to stop section marks appearing on plan views.
My problem is this: having finished general arrangement drawing plans and then starting to create reinforcement drawing plans with new sections to show the rebar, all the new section marks are appearing on the GA drawings that are already finished. Which means having to constantly go back to the GA drawings to check and hide the section marks that aren't needed.
Any help much appreciated
Thanks in advance
Mcinthepeaks
Thu, Dec 6, 2012 at 4:26:26 AM | Section marks appearing on plans
jimmykingy1
use view templates with filters
I filter our sheet/ publication views under different series of drawings.  eg 00-GA, 31- Windows, 90- External works.  then create a filter for each series and you can turn on /off setion marks independantly.  eg. GA drawings only show GA sections.
Takes a while to set up and maybe there's an easier way but I find this allows for total control....but ANY views on sheets should be determined by View templates (apart from in exceptional circumstances) - do not adjust on-the -fly  as it'll only cause problems in the long run
hope that helps
Detail section marks appearing EVERYWHERE!!!! RAC 2008
Fri, Feb 8, 2008 at 1:01:06 PM
section marks
Tue, May 17, 2005 at 12:54:13 AM
"Referenced From" Issue with Section Marks
Mon, Feb 6, 2012 at 2:55:01 PM
How to make section marks smaller?
Wed, May 9, 2007 at 4:47:08 PM
Section marks w/ SIM
Thu, Feb 23, 2017 at 12:37:36 PM
14
Page generation time: 0.6791
