Forums >> Revit Structure >> Technical Support >> GRID LINES NOT VISIBLE!
Wed, Dec 5, 2012 at 4:49:35 PM | GRID LINES NOT VISIBLE!
SofiaClark
I am starting a new project and I used the copy/monitor tool to copy levels, grids, walls and columns.  Everything copied into my model OK except for the gridlines.  They are there, just not visible.  I know this because I tried to just draw them in and my grid line came in as 6.  I know then that I copied grids 1-5.  I made sure that they are not just hidden and that "Grids" is checked in visibility/graphics window.  Any ideas?  Thanks.
Thu, Dec 6, 2012 at 7:47:53 AM | GRID LINES NOT VISIBLE!
From your view do a ZE and then look for them - they are out in space.
Thu, Dec 6, 2012 at 10:13:51 AM | GRID LINES NOT VISIBLE!
SofiaClark
Thank you.  I discovered that my client had put their grids in a scope box and they weren't copying over correctly using the copy/monitor tool.  Once I removed them from the scope box in their file, I simply did a cut/paste to same place into mine.
disappearing grid lines
Wed, Apr 19, 2006 at 5:44:48 PM
Grid Labels not visible while drawing a grid
Mon, Oct 15, 2012 at 3:29:21 PM
Grid Partial Visibility
Wed, Aug 3, 2016 at 1:08:39 PM
GRID LINES CUT
Fri, Jul 26, 2013 at 8:00:03 AM
2'x2' Diemsional Grid
Wed, Feb 5, 2014 at 2:10:47 PM
Page generation time: 0.6825
