Forums >> Revit Building >> Technical Support >> 2012_need to add a fixed dimension setting to a family
Wed, Dec 5, 2012 at 11:35:45 AM | 2012_need to add a fixed dimension setting to a family
archidozer79
I've created a desk in the furniture family category. The desk has three parts, a center desk and two wing desks (right and left). I want to be able to insert the family into a project and edit the various sizes of the desk through the type properties...which I've been able to do just fine using type dimensions.
My problem is that I want to be able to make this desk adjust in 6" increments. I've got the min & max set where I want, I just want someone to have the ability to adjust the size...with 6" variables only. How can I round to the nearest 6"?
Wed, Dec 5, 2012 at 12:10:15 PM | 2012_need to add a fixed dimension setting to a family
Go ahead and create multiple types and set the dimension in the type......  It would be a type parameter.
Wed, Dec 5, 2012 at 3:42:05 PM | 2012_need to add a fixed dimension setting to a family
TKennedy
4 Stars: 8 Votes
I would recommend using WWHub's method, especially if it's a type parameter. It will be much easier in the long run. However, it is possible, it's just a bit of a PITA. I have a shelving unit that needs to adjust at 6" increments from 2' to 5', and still be an instance parameter (I also wanted to keep the grips available without letting people adjust a shelf to a non-standard size). Here is the formula I ended up with, it's basically a whole bunch of nested IFs & ANDs that checks every possible size within my range (and also makes your eyes cross if you look at it too long).
if(Width < 2', 2', if(Width > 6', 6', if(and((Width > 2'), (Width < 2' 6")), 2', (if(and((Width > 2' 6"), (Width < 3')), 2' 6", (if(and((Width > 3'), (Width < 3'  6")), 3', (if(and((Width > 3'  6"), (Width < 4')), 3'  6", (if(and((Width > 4'), (Width < 4'  6")), 4', (if(and((Width > 4'  6"), (Width < 5')), 4'  6", (if(and((Width > 5'), (Width < 6')), 5', Width)))))))))))))))
Edited on: Wed, Dec 5, 2012 at 3:42:29 PM
Wed, Dec 5, 2012 at 3:57:37 PM | 2012_need to add a fixed dimension setting to a family
archidozer79
That's what I was looking for...something similar to a stair tread where when you grab the grip & drag it, it's still a real number. (wish I had said that first).
Thanks! I'll see if it works.
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ]
Sun, Aug 24, 2008 at 12:08:50 PM
15
Setting Default Dimension Family
Tue, Sep 29, 2009 at 12:55:17 PM
Dimension line fixed distance from an Object
Tue, Aug 22, 2017 at 8:18:26 AM
Adding mullions to a fixed or casement window
Mon, Feb 27, 2006 at 1:52:13 PM
Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
Wed, Jun 10, 2015 at 9:18:40 AM
Page generation time: 1.1089
