26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Railings
Is there a way to join separately constructed railings? I'm using 2012. When you have a railing along a hallway between two stairs how do you connect them? Each stair has its own railing so the railing on the hall can be from one or the other but it cannot be continuous. You get a disjoint where the next railing begins.
While I'm at it. Has Revit solved the switchback stair problem where you can't overlap stair runs?
Thanks is advance.
Watch this: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0505-Stair_by505
You have to update your Revit version
Cheers
Thanks! I'll give it a go.
RAILINGS RAILINGS????? |
Wed, Oct 1, 2008 at 3:48:49 PM
Frenc h railings |
Wed, Feb 18, 2009 at 2:51:56 PM
11
Problems attaching railings to stairs |
Mon, Dec 2, 2013 at 10:49:14 AM
stair railings-inserting glass |
Mon, Dec 9, 2013 at 11:37:40 AM
Dimensioning railings |
Fri, Jul 24, 2009 at 3:04:00 PM
