23 Users Online (21 Members):
Forums >> Revit Systems >> Technical Support >> Mechanical Tag
2 Posts No Rating |
I have been trying to create a mechanical equipment tag that can be editable within a model. I have tried to create one using the generic tag template. I can't find a parameter that will be editable when loaded into a project
That is because you are using a generic tag template.
I do not have MEP on this machine but you should have the proper template available.
2 Posts No Rating |
I have tried to find a mechanical equipment tag template to no avail
6 Posts No Rating |
There is no template for mechanical equipment tag.
Start with a generic annotation then change the family category to Mechanical Equipment Tags. Once you have done this you will seee the parameters under this category including mark as I have done in the attached.
Open the stock mechanical equipment tag - save it under a new name and modify it.
Change the family but keep the TAG |
Thu, Jan 24, 2013 at 1:24:16 PM
Tag Issues - Attached Leader Unwanted Offset |
Mon, Dec 31, 2012 at 12:46:55 PM
All my mechanical equipment is showing up on all the levels |
Mon, Jun 11, 2018 at 2:55:08 PM
ARCHITECTURAL PLANS IN MECHANICAL MODEL |
Fri, Jun 3, 2016 at 2:40:47 PM
Room Tag selectively or filter |
Wed, Feb 3, 2010 at 3:49:19 PM
