Forums >> Revit Building >> Technical Support >> Model Pattern Not Moving Independently
Mon, Dec 3, 2012 at 1:23:46 PM | Model Pattern Not Moving Independently
JTG76
Hello, all!
I've run into a problem with trying to create brick quoins. I created a wall-hosted generic model and set the material to be "by category." I gave it its own subcategory name so I could apply the brick model pattern to it from Object Styles. The pattern shows up and all, but for some reason, I cannot move the model pattern lines of the component. What happens is, I try to align the quoin's coursing with the building's brick coursing, but it moves the entire component, and the pattern stays locked in place with the dimensions of the quoin component.
I have decided to just create a wall type that is just the brick material of just the quoin thickness, since I know Revit will simply treat it like a regular wall, and that'll be that. However, can someone explain to me why I cannot adjust the lines of the pattern of the component? (Quoins aside, I just want to understand the way the features work better in case I ever create something that will be of brick (not a quoin).
Thanks a bunch for any help. I really appreciate it.
Sincerely,
Jason
Mon, Dec 3, 2012 at 4:10:18 PM | Model Pattern Not Moving Independently
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't suppose you could upload the family ? There's a couple things I can think of but I'd like to have a look.
Wed, Dec 5, 2012 at 2:13:37 PM | Model Pattern Not Moving Independently
quinn
NM I see the problem your facing.  Not sure why the model pattern assigned within the project does not adjust either.  You could always just make an in-place model instead.
Edited on: Wed, Dec 5, 2012 at 2:29:31 PM
Moving Floor Levels Independently
Thu, Feb 25, 2010 at 1:37:17 PM
Electrical components moving when reloading arch model
Mon, Jan 5, 2015 at 9:01:02 AM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Question About Model Pattern
Tue, Feb 19, 2013 at 2:40:21 PM
Page generation time: 0.5341
