10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Family Object not displaying properly
11 Posts No Rating |
I'm re-learning Revit after a 2.5 year hiatus and I'm having some frustrating problems I hope some of you can help me with.
I have this Family Object of a vanity sink (Capture1.png) and for some reason, it keeps showing a line on the plans that is no where to be found in the family object itself (Capture2.png & Capture3.png). What is it and how do I make it go away!?
The blue lines in 3 are the reference planes that control the hole in your counter.
The circle is the hole. It shows in 2 because your lav doesn't block it. A model sink woul as would a masking region in the family if the sink is just 2D lines in plan.
Thanks for your suggestions, but I'm wondering if it must be something else. Just as a test, I opened the family and deleted EVERYTHING (Capture1b) and loaded it back into the project. It still looks like this (Capture1a). Any other ideas or can you tell me if there's a way to view anything that might still be hidden that I'm somehow missing?
Edited on: Mon, Dec 3, 2012 at 1:57:21 PM
Did you only erase everything in the 3D view and not the plan/sections/elevations? If so, there are likely some 2D symbolic lines in the plan view.
You're probably right about the other views. How can I access them? I'm sorry to ask such a simple question, but I've been trying to figure that out without any success.
2d lines are in 2d views - like plans - sections - elevations.
The other views were helpful. I (mostly) got it to do what I wanted. Thank you.
windows in elevation and 3d not displaying correctly |
Thu, Oct 6, 2016 at 9:15:31 AM
Subcategories in export layer setup not displaying properly when exported |
Tue, Jul 31, 2012 at 10:50:40 AM
Underlays not displaying properly |
Wed, Sep 6, 2006 at 11:57:53 AM
Color Scheme Dialogue Box not displaying Properly |
Fri, Oct 11, 2013 at 12:17:02 PM
3D view with photograph background displaying incorrectly |
Fri, Sep 19, 2008 at 2:52:55 AM
