Forums >> Revit Building >> Technical Support >> Adding new materials to accurender library
Fri, Jan 20, 2006 at 7:32:55 AM | Adding new materials to accurender library
puzzle
4 Stars: 10 Votes
Is it possible to add new textures/materials to accurender. I added a colorbond bitmap into the accurender file but it doesn't show in Revit. Is there a tutorial? Puzzle
Macca
Sunshine Coast
QLD Australia
Fri, Jan 20, 2006 at 9:26:44 AM | RE: Adding new materials to accurender library
orv
4.5 Stars: 7 Votes
Place jpeg/bmp in Revit rendering/materials folder. (application data/autodesk/revit_?/rendering/accurenderredist/support/material) (? is version of revit you are using) Go into revit/settings/materials. Select any material and duplicate. Give it new name In Accurender-material box select arrow Right click any existing material and select New/Default Grey Go to maps tab, and Add Go to above location and select your material OK twice and save as a User material
Sun, Jan 22, 2006 at 3:46:36 AM | RE: Adding new materials to accurender library
puzzle
4 Stars: 10 Votes
Thanks orv Macca
Sun, Jan 22, 2006 at 5:16:12 PM | RE: Adding new materials to accurender library
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just to simplify. Adding a bitmap to the accurender library location does nothing. You need to create a material in accurender to then use this bitmap. For all new materials we have a separate mlib file where all custom materials are kept. This way we can ensure no materials are lost when a new release is installed. HTH.
Thu, Aug 30, 2007 at 5:46:07 AM | Adding new materials to accurender library
stedol
I have tried to do what orv said, get all the way through it and a access denied message apears and it will not let me create the new material using the required jpeg. HELP!
Fri, May 22, 2009 at 4:08:56 PM | Adding new materials to accurender library
Tim130
Is there anywhere online to download 'accurender' files?
Fri, May 22, 2009 at 4:28:15 PM | Adding new materials to accurender library
4 Stars: 205 Votes
Here: http://www.accustudio.com/
Fri, May 22, 2009 at 4:35:46 PM | Adding new materials to accurender library
Tim130
Cheers Typhoon!
Thu, Nov 19, 2009 at 4:01:18 AM | Adding new materials to accurender library
abbeydesign
I need similar help, using Revit Architecture 2008 I have previosly been able to apply AccuRender images to my materials saving the results to the 'USER' folder.  when I try to do it now I get an 'Access is Denied' error message.  How do I get round this?
Thu, Nov 19, 2009 at 4:07:36 AM | Adding new materials to accurender library
4 Stars: 205 Votes
Maybe because you don't have rights to save in that folder, try using the ADMIN rights.....
Thu, Nov 19, 2009 at 5:44:18 AM | Adding new materials to accurender library
#11
abbeydesign
Thanks for the swift response.  windows 'User Account Control' was switched on.  I turned it off and hey presto everything works fine.  God bless Bill Gates and all who sail in him.
Accurender materials not appearing in VIZ
Mon, Jan 21, 2008 at 5:27:44 PM
Accurender situation
Fri, Mar 30, 2007 at 1:34:58 PM
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ]
Fri, Aug 8, 2008 at 6:11:21 PM
31
Accurender Plants Library
Mon, Feb 18, 2008 at 12:21:25 PM
Accurender 4 material library onlien for download
Thu, May 29, 2008 at 8:02:42 AM
Page generation time: 0.9287
