Forums >> Workflow & Implementation >> Worksets >> Synchronization
Sun, Dec 2, 2012 at 10:11:27 AM | Synchronization
kulfi
we are working on central file but some time it does not synchronize can you tell me what is the problems why it can not.
thanks
Sun, Dec 2, 2012 at 10:21:45 AM | Synchronization
Hopefully, nobody is working directly in the central file but in their own local.  The file will not sync while another user is doing so.  If those ar not your problem, then it is a network issue.
Sun, Dec 2, 2012 at 10:28:49 AM | Synchronization
kulfi
ok thanks now i have another question regarding this issue if i loose some work from the central due to anyone working direct on the central file and restore the central file from my backup how can i replace the file so that all the users do not loose the synchronization process.
Mon, Dec 3, 2012 at 10:24:24 AM | Synchronization
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Just have them create a new local file from the new central file.
Mon, Jan 28, 2013 at 6:53:08 PM | Synchronization
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I linked my autocad files with revit from the revit ribbon.  I am mainly working in Revit with the linked autocad files. So every time I save in Revit, is it saving my work in autocad as well? Which program is my local file and which one is my central file? How can I tell if the file I am working with is a central file or a local file?  While at college, I tryed to open my own revit file, and I got a message saying that I am not the creator of the linked files. Instead the school computer was recognizing my school username. How in the world did that happen? I created my linked files at home. I am the only user of my linked files.
Edited on: Mon, Jan 28, 2013 at 6:54:37 PM
Tue, Jan 29, 2013 at 7:41:32 AM | Synchronization
Revit will not save your autoCAD files.  The only way to do that is to export Revit.
Did you enable worksets?  If so, then it is up to you to name your files in a manner that tells you what you are in.  Our process:
  1. Enable worksets
  2. Save as (save as central is default so therefore is ghosted.)  We put central in the name of the file and save on our network.
  3. Either
  • Now do another save as for your local in your computer (I put local in this file name).
  • Or close the file and open the central with create new local checked and save this file to your system.  << This process will put your name apended to the central's name.
Pipe Fittings move during Synchronize
Wed, May 9, 2012 at 1:32:03 PM
Can't link with Central file
Tue, Apr 7, 2009 at 6:27:09 AM
A local file enslaved to another local file? Is that possible?
Thu, Jan 7, 2010 at 1:59:11 PM
Remote users on WAN, WAFS?
Thu, Nov 3, 2005 at 5:55:43 PM
Page generation time: 1.4670
