12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> design option
18 Posts No Rating |
sir,kindly give the procedure ,how to work with design option.I have plan with different option.
thank u.
52 Posts No Rating |
hai,
U can get to know the procedure on how to work on design option through Revit tutorials or help. I think this will be able to help u understand.
regards
Consider viewing this online webcast that Autodesk conducted for Design Options.
http://tinyurl.com/95pco
This webcast is for designers who want to get into the trenches with the Revit Design Option feature. Have you ever wanted to explore two different window and roof configurations without having to make copies of your design? Autodesk Revit can help designers explore many different design configurations within the same building information model, using the powerful “Design Option” feature. Learn how to explore different design requests right in front of the client for fast approval with minimal change orders later in the process.
While this webcast was done using Revit 7, I believe its a good source to handle your basic questions about Design Options.
Cheers!
LinkedIn Profile:
- http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com |
Design Option Issue - walls in 1 design option cutting thru a 2nd option |
Thu, Oct 21, 2010 at 11:55:04 AM
Design Option view setting |
Fri, May 16, 2014 at 8:02:11 PM
Design Options - black hole. |
Wed, Feb 14, 2007 at 12:54:40 PM
Design Option Sharing |
Mon, Dec 6, 2010 at 10:02:19 AM
12
Railing wont host to stair created in design option |
Mon, Oct 24, 2011 at 3:54:39 PM
