Forums >> Revit Building >> Technical Support >> Rendering special opaque walls
Sat, Dec 1, 2012 at 3:51:28 PM | Rendering special opaque walls
bmfranke
Hello all,
I am trying to render a glass wall that has a high level of opacity (high degree of being frosted, per se) at the wall's base, while at the top of the wall I would like for the glass to be clearer (lesser degree of being frosted). Does anyone know how to do this? I have tried changing the render appearance to conform to a gradient, but I can't figure out how to turn the gradient 90 degrees, or tell Revit that I am trying to render a glass wall versus a colored wall?
Thanks for your help.
Sat, Dec 1, 2012 at 3:52:16 PM | Rendering special opaque walls
bmfranke
Also should have stated I'm using Revit 2012...
Glass is clear but when rendering it is Opaque
Mon, Feb 6, 2012 at 8:38:07 AM
how to make walls opaque in a camera view
Fri, Jan 4, 2013 at 11:22:18 AM
Problem with opaque text showing transparent
Mon, Feb 24, 2014 at 9:20:10 AM
SPECIAL SCHEDULE
Wed, May 2, 2018 at 1:14:01 AM
Fill patterns do not print opaque over image files
Sun, Jul 10, 2005 at 9:56:33 PM
Page generation time: 4.1221
