Forums >> Revit Building >> Technical Support >> Revit 2012 - Attaching top of Curtian Wall question
Fri, Nov 30, 2012 at 7:38:52 PM | Revit 2012 - Attaching top of Curtian Wall question
crcgrp
I have a curtain wall made up of typical storefront sytem.  The roof is supported by exposed Glulams with exposed T&G sheathing.
There will be blocking between the glulams filling the space between the top mullion of the curtain wall and the bottom of the T&G.
The Glulams and T&G are sloped.  Is there a way to Attach the top of the Curtain Wall to the Glulam blocking?
If it wasn't sloped than of course I could just set the height of the glulam.
Any ideas?  Thanks in advance!
Sat, Dec 1, 2012 at 8:33:39 AM | Revit 2012 - Attaching top of Curtian Wall question
I would probably just sketch the CW profile.
Other options - add a full thickness roof in a workset off in all views - and attach CW to that.
Curtian Walls in Window Schedules
Thu, Jun 28, 2007 at 3:12:57 PM
Curtain Wall and Curtian Doors
Fri, Nov 5, 2010 at 10:19:17 PM
How to make the top of the wall not horizontal?
Sun, Jan 23, 2011 at 7:17:41 AM
Attaching walls to stairs
Tue, Aug 22, 2017 at 12:20:10 AM
13
Newbie arched top wall question
Thu, Apr 2, 2009 at 10:14:12 AM
Page generation time: 1.8337
