Forums >> Revit Building >> Technical Support >> multifamily - Unit plans
Fri, Nov 30, 2012 at 7:45:09 AM | multifamily - Unit plans
joe5676
revit arch 2013
I've worked with larger multifamily multistory projects before, and have successfuly utilized groups for the unit plans, but the project im working on now is an adaptive resuse and has different floor to floor heights.  I'm running into an issue when i copy groups up to shorter floors with walls punching through the level above.  and changing one obviously changes them all.
what would you recommend to handle the walls on the interior of the units?  i feel stumped.
thanks all.
Fri, Nov 30, 2012 at 8:04:08 AM | multifamily - Unit plans
I believe I set these walls to go to the level above with a negative offset and that worked for me.
Fri, Nov 30, 2012 at 8:11:17 AM | multifamily - Unit plans
joe5676
for me the level i created my unit plans is on(2nd flr) is 17' high, when i copy it up to 3rd instead of my walls being -4" from 4th like on 2nd they keep the same overall height and protrude up 8".  so changing it drops the 2nd floor walls.  so theyre all staying the same overall height.
hub if you can explain how you did this and it worked i'd appreciate it.  just isnt working for me.  trying to avoid multiple groups and complications if possible just not seeing how else to do it.
thanks
Fri, Nov 30, 2012 at 8:16:46 AM | multifamily - Unit plans
joe5676
also, if you have any idea how i can get the walls in the top floor to attach to the roof without modifying the rest of the levels I'd appreciate it.  another issue I'm having.
Fri, Nov 30, 2012 at 10:32:18 AM | multifamily - Unit plans
If it is a sloping roof, you will have to use attach.
If floors or roofs that are flat and the walls are set to level above, simply edit the floor / roof sketch and when finished, answer that you want it to cut out intersecting walls.
Fri, Nov 30, 2012 at 11:29:49 AM | multifamily - Unit plans
joe5676
thanks I'll give it a shot!
Fri, Nov 30, 2012 at 1:23:19 PM | multifamily - Unit plans
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
I'd be interested to know if that works, thanks in advance!
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Why not use nested families for multifamily unit types?
Tue, Mar 7, 2017 at 10:09:34 AM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
Blank mark door tags for unit plans
Tue, Aug 16, 2011 at 11:40:36 AM
Area and Room Tags
Thu, Apr 16, 2009 at 2:48:06 PM
Callout of Typical Rooms in Hotel/Multifamily Residential Project
Wed, Mar 12, 2014 at 7:38:36 AM
Page generation time: 0.4610
