Forums >> Revit Building >> Technical Support >> Section head shared parameter
Fri, Nov 30, 2012 at 3:19:07 AM | Section head shared parameter
Lochnesska
Lochnesska Avatar
Hello. My firm has strict library rules and layers code. They all use AutoCAD but I'm quite stubborn and I still think that Revit is so much better for architecture. However, I can use it so it's cool.
I've spent a lot of time searching any clue how to do this:
In section head, I don't want to know on which sheet this view is referenced, or any other of the 6 possible label parameters.
I want just a new shared parameter that I could tell the section that its number is 001 and the type (section or elevation). Unfortunatelly the possibility to pick a shared parameter in label is greyed out so I can't do this.
Any clue?
Using Revit 2013
Nessie
Revit 2013
Fri, Nov 30, 2012 at 3:26:45 AM | Section head shared parameter
Lochnesska
Lochnesska Avatar
In fact I realised that there is no information in the section head as long as you put the section on a sheet... I don't need this, I have to export to dwg for the presentation....
Nessie
Revit 2013
Fri, Nov 30, 2012 at 7:24:50 AM | Section head shared parameter
If want something dumb for CAD, then don't use a section head, make a symbol.
Fri, Nov 30, 2012 at 7:54:28 AM | Section head shared parameter
Lochnesska
Lochnesska Avatar
Could this symbol be attached to the section? That I don't have to do everything manually?
Nessie
Revit 2013
Fri, Nov 30, 2012 at 8:02:05 AM | Section head shared parameter
Can not be attached to a section cut.  Remember - this is dumb.
Hide Section Head in Shared File
Mon, Aug 30, 2010 at 7:14:49 AM
Shared Parameter's will not show in Schedules
Wed, Oct 9, 2013 at 8:36:07 AM
Trying to Import Filled Section Head
Mon, Jun 27, 2016 at 2:32:45 PM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
problem with section head
Sun, Nov 26, 2006 at 4:49:05 PM
Page generation time: 0.6010
