Forums >> Revit Building >> Technical Support >> Selecting Objects on floor below
Thu, Nov 29, 2012 at 2:12:46 PM | Selecting Objects on floor below
pksoccer16
Does anyone know why when using a crossing-window to select objects on a second floor plan that objects on the first floor plan below are also being selected.  This will cause major issues if objects below are deleted.  Any help would be appreciated.  We have verified that the floor plan view settings are standard.
Thu, Nov 29, 2012 at 2:26:47 PM | Selecting Objects on floor below
quinn
First check your view depth is it below the level if so you can select objects below.  Make sure the view range is set to the desired bottom of level.
Thu, Nov 29, 2012 at 2:30:04 PM | Selecting Objects on floor below
Revit is a 3D program.  Anything in the view (and view range) hidden by other objects or not, will be selected by crossing windows.  Every user needs to understand this and ALWAYS check their "funnel" to verify what they are selecting.
Thu, Nov 29, 2012 at 2:54:55 PM | Selecting Objects on floor below
pksoccer16
Yes I understand - it was a view range issue.  Thanks
Weird behavior when selecting objects
Tue, Nov 27, 2012 at 9:25:24 AM
Selecting-De-selecting objects.
Fri, Nov 25, 2005 at 10:12:01 PM
Revit moves objects just by selecting them?????
Wed, Jul 17, 2013 at 11:53:34 AM
Selecting Objects Help!!!!!!!
Wed, Jun 10, 2009 at 8:23:52 AM
Selecting objects from a list?
Mon, Aug 15, 2005 at 2:29:26 PM
Page generation time: 0.3362
