Forums >> Revit Building >> Technical Support >> Multiple referances to the same detail
Thu, Jan 19, 2006 at 5:58:14 PM | Multiple referances to the same detail
BS0450
BS0450 Avatar
3 Stars: 1 Votes
Hi again guys, I am having a hard time (first month with revit) again. What I want to do is to refer multiple times to a foundation section. IE. I have a type 'A' foundation throughout most of my building and I would like to add a tag that would refer back to the one detail section that I have cut and detailed. The temporary solution I have come up with is simply drafting the tags in my view. Any help is very much apreciated. Thanks
Thu, Jan 19, 2006 at 10:40:30 PM | RE: Multiple referances to the same detail
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When you create a new callout or section you can use the reference other view check mark to have it link to an already created view.
Fri, Jan 20, 2006 at 1:50:53 PM | RE: Multiple referances to the same detail
BS0450
BS0450 Avatar
3 Stars: 1 Votes
Thank you Mr. Spot I figured it was a small check box or something I was over looking.
multiple detail tags for same detail
Fri, Oct 6, 2006 at 11:05:08 AM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:09:24 AM
Detail components in multiple views.
Tue, Aug 18, 2009 at 2:46:35 PM
Multiple revit building with one standard detail sheet
Mon, Jan 21, 2008 at 12:28:12 AM
Tue, Jul 31, 2007 at 7:52:46 PM
Page generation time: 1.2942
