Forums >> Revit Building >> Technical Support >> reflective glass on the outside- not reflective on the inside
Thu, Nov 29, 2012 at 12:50:28 PM | reflective glass on the outside- not reflective on the inside
anasmiley
How can I have my model glazing show clear from the inside so I would see the exterior but yet show reflective when I'm looking at it from outside? Is that possible in Revit?
Thu, Nov 29, 2012 at 2:43:24 PM | reflective glass on the outside- not reflective on the inside
I don't know - you test this out.  Set your glass to reflective, then on one side, paint it as transparent.  Paint is a one surface only tool.
Please come back with a view from both sides to let us know.
Thu, Nov 29, 2012 at 3:24:59 PM | reflective glass on the outside- not reflective on the inside
quinn
Im assuming when your inside doing a rendering you would not want to see reflection and on the outside you would want to see it.  You can create a two panel family for your windows.
One with reflection for outside rendering
One for inside thats transparent.
Use the on/off parameter for both types of panels in the family so you can turn one on and the other off.
That is another possibility.
Fri, Nov 30, 2012 at 7:46:21 AM | reflective glass on the outside- not reflective on the inside
anasmiley
Solved it Smile The glazing needs to be double pane! yay
Ceilings, walls and columns are reflective
Fri, May 27, 2016 at 7:59:39 PM
Can you create mirrored walls (shiney reflective ones) with Revit?
Tue, Nov 25, 2008 at 12:07:26 PM
andersen window issue
Wed, Aug 16, 2017 at 9:08:12 AM
Rendering Exterior Glazing
Mon, Feb 20, 2012 at 2:39:01 PM
rendering/ lights
Sun, Jan 2, 2011 at 6:58:02 PM
Page generation time: 1.8582
