Forums >> Revit Building >> Technical Support >> Detail / Drafting Views
Wed, Nov 28, 2012 at 11:50:20 PM | Detail / Drafting Views
Bretto
Trying to move away from detail lines, masking & filled regions etc. Thoughts on what others are doing...this is mainly to keep all keynotes or tags upto date and have a bit of quick controll over changing detail items with quick swap out instead of having umpteen different views loaded to template.
Thu, Nov 29, 2012 at 7:06:31 AM | Detail / Drafting Views
You are on the right track.  We rarely use anything but the model for plans, elevations, building and wall sections.  Even in details, I prefer using edit cut profile to adding filled regions for most model elements.  We do add repeating detail items/ window/ door/ stud/ framing detail elements to detail views but not normal sections.
There is no reason to have "umpteen different views" in your template.  For drafting - detail views, use a library project file that has these set up on organized sheet views so you can find what you need and load the view into you model using the insert  / insert from file process.
Thu, Nov 29, 2012 at 9:18:19 PM | Detail / Drafting Views
Bretto
sounds good, im glad im on the right track for a change..ty Smile
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:05 PM
Head, Jamb, Sill Details - Detail vs. Drafting Views
Wed, Jul 15, 2009 at 3:20:17 PM
DRAFTING VIEWS
Fri, Oct 13, 2006 at 3:34:29 PM
Default setting for detail title on inserted drafting views
Thu, Mar 21, 2013 at 9:41:45 AM
Page generation time: 1.5050
