Forums >> Revit Building >> Technical Support >> Room numbers
Thu, Jan 19, 2006 at 4:52:05 PM | Room numbers
triciaw
I am having a problem with revit recognising two rooms as one. When I tag the second room the message comes up with 'Room Tags refer to the same room'. Can anyone tell me what it is that is defining the room?
Fri, Jan 20, 2006 at 3:27:25 AM | RE: Room numbers
Molonesh
When you press the room tag' you see the frame around the room it tags. you may need to add boundry line to seperate the two rooms, and then it will work.
Room Tag Numbers
Tue, Jul 8, 2014 at 7:22:54 AM
11
Room Numbers in Schedules
Wed, Jan 25, 2006 at 3:26:56 PM
Phasing
Thu, Jul 30, 2009 at 8:01:36 AM
Schedule will not tracj all room names and numbers [ 1 2 ]
Fri, Jul 30, 2010 at 5:15:35 PM
16
Room name and numbers - Yet another question
Tue, Sep 14, 2010 at 3:10:43 PM
Page generation time: 1.0051
