Forums >> Revit Building >> Technical Support >> one proeperty of the railing
Wed, Nov 28, 2012 at 3:13:17 PM | one proeperty of the railing
xixiha
One property of the railing confused me.
Brak pattern at > angle greater than> angle
This angle is the railing turning on the horizontal plane or on the vertical plane(like the railing bending at landing)?
Wed, Nov 28, 2012 at 4:04:15 PM | one proeperty of the railing
Your help is always your first place to look.  Under railings, they have the type properties listed and it says:
Angled Joins If 2 railing segments meet at an angle in plan but do not connect vertically, Revit Architecture can add vertical or horizontal segments to create a join or add no connector, leaving a gap. This can be used to create a continuous railing where the start of a stair run leading up from a landing cannot be displaced by one tread width. Join methods can be overridden on an connection-by-connection basis. See Modifying Railing Joins.
People who are looking for books on revit should start by just becomming familiar with the help.
Wed, Nov 28, 2012 at 4:57:58 PM | one proeperty of the railing
xixiha
What you have posted is not what I am asking, see attached image, and I read the help before I ask, but the help didn't help me.
It says:
Break Pattern at The point along a railing segment at which the baluster pattern stops. Angle A value specifying the angle at which a pattern breaks. This property is available when Angles Greater Than is selected for Break Pattern At.
 I did some test and inclined to thnk it means a the horizontal angle.
Edited on: Wed, Nov 28, 2012 at 4:58:38 PM
Railing not shown in list
Mon, Jun 30, 2014 at 4:25:56 PM
rectangular railing
Mon, Nov 26, 2012 at 7:30:07 AM
Railing Turns Into Transparent Red
Thu, Aug 10, 2017 at 2:06:41 AM
Railing and Baluster Profiles not inserting on centerline?
Fri, Oct 5, 2012 at 2:26:20 PM
Newbie help: how to intersect railing with baluster
Wed, Mar 25, 2009 at 4:26:53 AM
Page generation time: 1.9326
