18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Revit 2013 Wall difference
Hi
I draw 2 walls, one is thicker then the other one (please see the attached image)
Now I want to move wall B down a bit, but when I move wall B, wall A is moved at the same time.
I try to disjoint these 2 walls, however the gap needs to be at least 200mm (too wide) .....
Would you teach me how I can move wall B without moving wall A, please?
(Other methods than redraw walls)
Thank you very much
you must lock the wall A, than move Wall B to the position you want ,and then unlok the wall A.
Actually, just pick the wall to be moved and check the options bar box to disjoin.
NOTE: if this wall has any associated dimensions or tags, then the disjoin will cause you to lose these intems. In that case, I usuall just pull the wall back so that it disjoins, move it, then stretch it back.
"I usuall just pull the wall back so that it disjoins, move it, then stretch it back."
This is the way I do it also
"just pick the wall to be moved and check the options bar box to disjoin."
I don't get that option on my option bar, am I missing something WWHub?
You did not pick move....
2013 - Stacked wall problems |
Thu, Dec 12, 2013 at 8:23:39 PM
Revit 2013 making walls by faces and some walls are very strange... please help! |
Wed, Jun 19, 2013 at 7:05:58 AM
Major Printing to PDF issues... Revit 2013 |
Tue, Jul 3, 2012 at 12:21:57 PM
wall placement Revit architecture 2013 |
Thu, Feb 7, 2013 at 4:30:45 PM
What is the difference Between Wall Finish Face and Wall Core Face |
Fri, Oct 16, 2009 at 10:54:02 AM
