Forums >> Revit Building >> Technical Support >> View template - different sun settings
Tue, Nov 27, 2012 at 7:28:52 PM | View template - different sun settings
jpmays23
Hi all,
I am trying to set up a view template for some exterior perspectives, and I want to have consistent lineweights, color, etc.  Obviously, i should create a view template.  However, I can't seem to figure out how to keep some things the same, but have different sun settings for different views.  To clarify, I do not want to have one master sun setting that applies to all views, because it makes some in too much shadow.  I'd like to keep things like visibility, lineweight, color, etc. consistent, but be able to adjust the sun settings on a view by view basis.
When I go to my Graphic Display Options in my view, I can't adjust the Sun setting, only the intensity of the sun, ambient light, and shadows.
Is it possible to make this adjustable by view?
Thanks,
JP
Wed, Nov 28, 2012 at 7:59:07 AM | View template - different sun settings
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I believe that you can apply your view template that you want so that all of your line weights etc look the same then apply the <None> template, it will hold all of your previous settings but give you all of the control to change whatever you want back
Wed, Nov 28, 2012 at 9:04:16 AM | View template - different sun settings
jpmays23
Ok.  The only problem with that is if I change any of the template settings, I'd have to reapply, then readjust my sun settings.
View Title with sun settings
Wed, Feb 12, 2014 at 9:29:32 AM
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides
Tue, Feb 10, 2009 at 2:19:03 PM
Render in cloud / sun settings
Tue, Jul 22, 2014 at 4:42:45 PM
ADJUSTING SUN SETTINGS
Wed, Aug 2, 2006 at 10:15:30 AM
Update View Template
Tue, Feb 10, 2015 at 8:22:55 PM
Page generation time: 0.8172
