Forums >> Revit Building >> Technical Support >> Glass appears Solid in new Phase
Mon, Nov 26, 2012 at 4:16:08 PM | Glass appears Solid in new Phase
designimpressions
Hi All, Does anyone know why glazed panels appear solid in when added to a new phase? I have an Existing Phase with windows placed and the panels are transparent. However, when I add the same windows in the New Construction Phase the panels appear solid (Not transparent). Thanks, Peter
Mon, Nov 26, 2012 at 11:28:12 PM | Glass appears Solid in new Phase
Thread Post Kudo! #2
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
In the 'View Properties' please check the 'Phase Filter' you are using and also whether 'New' is set to 'Overridden' in that 'Phase Filter' you are using in that view. Under 'New' in Phase filters if you change to 'By Category'  you can see the glass panels transparent.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Fri, Jan 4, 2013 at 6:07:39 AM | Glass appears Solid in new Phase
designimpressions
Sorry for late reply, it was to do with the overrides. Thanks.
glass appears black when rendering
Thu, Feb 16, 2006 at 5:36:21 PM
Rendering glass in revit 2009 [ 1 2 ]
Tue, Aug 4, 2009 at 12:02:07 PM
23
Glass behaving oddly
Thu, Nov 27, 2014 at 11:05:47 PM
Revit Renderings too dark and take too long
Wed, Jan 6, 2016 at 11:32:51 AM
Glass in doors transparent only on one side - any ideas?
Sat, Jun 7, 2025 at 1:32:50 PM
Page generation time: 4.5742
