Forums >> Revit Building >> Technical Support >> How to make raiing panel bending with the stair angle
Mon, Nov 26, 2012 at 10:38:03 AM | How to make raiing panel bending with the stair angle
xixiha
Using Revit 2013
I made a costomized railing panel for stairs, but finding it can't bend following the stair landing, nor can it fill in the left over. Is there any way to solve this? Or maybe I didn't model the family correctly? See attached image, the yellowed part is blank. Seems the stair doesn't how to fill my panel in.
Mon, Nov 26, 2012 at 10:57:10 AM | How to make raiing panel bending with the stair angle
This panel shape is always a problem.  Search through the forums because it has been brought up before.
Generic line based sweep
Sun, Jan 27, 2013 at 2:02:54 PM
Bar Bending Schedules Using Revit Structure 2012
Wed, May 9, 2012 at 11:15:53 AM
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:18 AM
13
Array on an angle
Fri, Apr 23, 2010 at 12:44:38 PM
12
Baluster extensions at bottom of stair runs.
Fri, May 15, 2015 at 9:53:56 PM
Page generation time: 0.7628
