Forums >> Revit Building >> Technical Support >> Projection and CUT
Sat, Nov 24, 2012 at 12:29:31 AM | Projection and CUT
kulfi
I am just new to Revit so Please can any one tell me in Objects Styles Menu there is Line Weight and in This there is Projection and CUT what are These.
Thanks
Sat, Nov 24, 2012 at 5:06:59 AM | Projection and CUT
4 Stars: 205 Votes
"Projection" = when you are not cutting the object.
"Cut" = When you are cutting the object.
projection vs. cut lines
Mon, Oct 31, 2005 at 2:29:38 PM
why my projection lines overlap cut lines.
Tue, Apr 10, 2018 at 7:41:07 PM
Toggle cut and projection lines
Tue, Mar 6, 2012 at 6:57:56 AM
Visibility Projection and Cut lines.
Wed, Nov 5, 2014 at 1:55:03 PM
Problematic Projection Lines In Section
Fri, Mar 16, 2012 at 8:31:43 AM
Page generation time: 0.3163
