31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Ribbon Windows
5 Posts No Rating |
How in the world do a create a ribbon window family that has vertical mullions w/ varied spacing (ie. one window panel is 6'-3", the next is 4', and then it repeats. Thanks
A quick fix would be to use an embedded curtain wall and space the mullions to suit your needs. I'll play around with the family editor tomorrow and see if I come up with a real solution
5 Posts No Rating |
thanks man!!
Personally i'd setup a curtain system with 10'-3" spacing mullions and then add additional mullions at the appropriate locations.
Alternatively you could model the window as a family using two arrays for the different spaced mullions that you could then use to define the window size.
ribbon issues |
Thu, Aug 27, 2015 at 10:14:04 AM
Revit 2012 Ribbon problem |
Tue, Jun 14, 2011 at 2:06:01 PM
Ribbon for Revit |
Sat, Aug 29, 2009 at 2:09:53 AM
Ribbon tabs 2011 |
Wed, Nov 23, 2011 at 2:08:46 PM
Ribbon Issues |
Tue, Jan 14, 2014 at 9:51:50 AM
