19 Users Online (17 Members):
Forums >> Workflow & Implementation >> Worksets >> working on two templates
26 Posts No Rating |
i have a arch engineer who is working on arch template not the file is to be transfered to the mechanical engineer who wants to start the work on mechanical template please can you tell me how is it possible.
Because template files have no effect on compatability between files. Only what is initialy contained in the file when a new project is started.
hth
He will start his own file with his template and link your file in.
what you means is that this type of problem can be saved by linking the templates or merging them together and and than the mechanical engineer can purge the arch templates can u please provide more informations how to work with this type of environment.
thanks
No, I meant exactly waht I said. The mechanical engineer uses his own template!
Read your help on linking.
It Means all the process of modeling will be linking the files or Else?
Where have my templates gone in 2012 |
Sat, Apr 7, 2012 at 9:09:06 AM
Family Templates |
Tue, Nov 26, 2013 at 9:56:21 AM
Cleaning up Templates and managing shared parameter files. |
Fri, Jun 10, 2016 at 8:16:29 AM
Revit 2015 Templates Not Working Correctly |
Thu, Sep 28, 2017 at 10:53:43 AM
Drawing templates |
Thu, Jun 10, 2004 at 1:41:36 PM
