Forums >> Revit Building >> Technical Support >> sloped subroof with crickets
Tue, Nov 20, 2012 at 12:12:08 PM | sloped subroof with crickets
evollmer
I'm trying to model a roof with the overall slope defined by sloped joists but additional crickets built on. The first time I built it, I used one edge to define the slope in the ‘edit boundary’ function, and it worked great for sloping the structure and main plane of the roof, but then the ‘modify sub elements’ tab grays out. So I flattened the roof and built my crickets, which worked fine, except I had to make the insulation variable to not have my beams kick back up where the crickets are, and as soon as I did that, it flattens out the bottom profile of the roof. I’m trying to avoid having to build this as two separate ‘roofs’ (i.e. structural joists and deck as an inclined plane and then a separate object that is the tapered insulation and membrane). Has anyone come across this before and figured out a good way to deal with it? Thanks!
Tue, Nov 20, 2012 at 4:00:33 PM | sloped subroof with crickets
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This post may be able to help you.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=17430
adding crickets to a sloped roof structure
Mon, Oct 16, 2017 at 9:28:29 AM
Flat roof with crickets
Mon, Jun 9, 2008 at 3:50:45 PM
Roof Crickets (How to do them)
Wed, Nov 4, 2009 at 3:43:47 PM
Low slope roofs: What is the best way?
Thu, Feb 14, 2008 at 7:51:36 AM
crickets for complex roof w/ multi slopes attached to beams
Fri, Aug 1, 2008 at 3:13:45 PM
Page generation time: 0.0446
