21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Room Tag is lost visibility is on
16 Posts No Rating |
Version Revit Architecture 2013, update 1 and 2
It's amazing how much bugs Revit 2013 has (especially when you started with earlier versions and converted them) and I am afraid this is another bug:
Some room tags, rooms are not visible anymore on a floor plan. I looked at the visibility settings, checked reveal hidden elements, etc. (the usual). Alas, I could not find my room.In the plan two other rooms are visible, the rest not.
Ok, then I tried to delete all the rooms throroughly then I made a new room but we keep on having the same problem:
None of the created elements are visible in Floor Plan: .... You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I checked the active view, its parameters, visibility settings as well as the plan regions and their settings.
What else can I do?
I just looked at a room schedule and found that a lot of rooms have Non Placed levels and Area is also not placed...strange...
Have you checked with worksets?
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
Have you checked limits of 'Room'?
Pavan Reddy
Revit Manager
Not placed rooms are rooms that were deleted from the plans. Up until 11 I think, deleted rooms were completely removed from the file. Now they remain in the schedule so that you have the opportunity to copy and use them elsewhere. When they are no longer useful, delete them in the schedule and that completely removes them.
Visibility Parameter in Room Tag |
Fri, Jun 4, 2010 at 6:01:09 PM
Visibility elements in a room tag |
Mon, Aug 9, 2010 at 2:58:33 PM
Room tag not showing in only one room. [ 1 2 ] |
Sat, Sep 27, 2025 at 3:40:00 AM
15
HELP!!! Problems with Room Tag |
Tue, Dec 3, 2013 at 7:17:38 AM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
