Forums >> Revit Building >> Technical Support >> Wall joins (or wall corners)
Sat, Nov 17, 2012 at 1:15:35 PM | Wall joins (or wall corners)
Hi guys,
I'm having troubles with the corners of my walls. I want them to turn the corner to finish well. I did play with the wrapping options via the properties menu, but no results... It changes, but not the way I want it.
Just look at the 2 pictures I've attached.
I hope you can help me. Thanks!
Sef.
Sun, Nov 18, 2012 at 5:04:19 AM | Wall joins (or wall corners)
4 Stars: 205 Votes
Select the wall then "Edit Type" - "Wrappint at inserts"
Sun, Nov 18, 2012 at 10:40:59 PM | Wall joins (or wall corners)
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Looks like you are using Curtain wall.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Wall opening affects wall joins
Fri, Aug 6, 2010 at 5:05:05 AM
wall Joins
Thu, Jul 13, 2006 at 1:23:01 AM
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
Page generation time: 0.7877
