Forums >> Revit Building >> Technical Support >> line based cabinet family
Fri, Nov 16, 2012 at 2:48:10 PM | line based cabinet family
jbhearn
Hi,
Please find the attached file.
Can anyone help figure out how to add a family type that would allow me to change the type of cabinet door used? I can add a parameter named Style 3 and understand the check box determines which parameter is visible in the family type but I can't figure out how to add the families to Style 3. This file is nested into another family file.
Please help!!
Thanks,
Brian
Sat, Nov 17, 2012 at 9:17:53 AM | line based cabinet family
coreed
coreed Avatar
4 Stars: 16 Votes
Read this article, it should get you going in the right direction:
http://www.cadsoft-consult.com/blogs/architecture/2010/06/revit-families-endless-combinations-with-nested-families-and-the-family-type-parameter/
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
Line based generic model family- RAC2008
Wed, Apr 22, 2009 at 12:00:15 PM
How do I cut cabinet to host recessed light? Using Revit 2009
Thu, Apr 17, 2008 at 10:00:03 AM
3D line based hosted family template or solution
Sat, May 2, 2009 at 1:46:17 PM
line based family inside face baced family
Mon, Aug 6, 2012 at 9:15:42 PM
Page generation time: 8.9864
