Forums >> Revit Structure >> Technical Support >> Placing Weather Vane On Roof
Thu, Nov 15, 2012 at 10:31:39 AM | Placing Weather Vane On Roof?
KposK17
5 Stars: 2 Votes
I'm currently making a barn, and no barn is complete without a weather vane on top. However, I cannot seem to place it on the very top edge of my roof. Im not sure how to go about doing this because the top edge isn't a true work plane. Im very new to revit and thank you in advance.
Edited on: Thu, Nov 15, 2012 at 10:32:52 AM
Thu, Nov 15, 2012 at 10:35:14 AM | Placing Weather Vane On Roof
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you make the weather vane? Does it need to be hosted to a face or a plane?  You can create a reference plane at the point where you want the weather vane to go and host it to that plane.  Photos are always helpful along with as much helpful information as possible.
Thu, Nov 15, 2012 at 10:36:54 AM | Placing Weather Vane On Roof
thedboys95
5 Stars: 2 Votes
Hello KposK17. I am very new to Revit as well and I had a similar problem placing items on my roof as well but I found that you have to make sure you work in the ceiling plan level 3 and create a third elevation at the very top of the roof in order to work in the top plane. But I could be wrong
Thu, Nov 15, 2012 at 10:40:22 AM | Placing Weather Vane On Roof
BTB2
5 Stars: 2 Votes
go to elevation then make a new elevation at the level you want
Thu, Nov 15, 2012 at 10:41:28 AM | Placing Weather Vane On Roof
KposK17
5 Stars: 2 Votes
i did not make the weather vane, just downloaded it yesterday. still not sure how to explain this but i'll attach a file of my project.
Thu, Nov 15, 2012 at 10:48:41 AM | Placing Weather Vane On Roof
If it is a work plane based family, simply add a new reference plane and set it.
Edited on: Thu, Nov 15, 2012 at 10:49:18 AM
Thu, Nov 15, 2012 at 10:52:02 AM | Placing Weather Vane On Roof
KposK17
5 Stars: 2 Votes
ok thanks. and how do i go about making a reference plane? Im still very new to this
Thu, Nov 15, 2012 at 10:59:40 AM | Placing Weather Vane On Roof
Go to an elevation or section view ... home tab ... pick ref plane and draw it... Very hard to do.
*New to Revit* - How to 3D model weather barriers?
Wed, Oct 8, 2014 at 1:43:41 PM
Weather Ledge, Drip Ledge, Sheeting notches? HELP!
Fri, Apr 4, 2008 at 11:46:41 AM
Serious problems with roof
Wed, Nov 24, 2010 at 2:54:46 AM
14
placing beams
Fri, Jan 8, 2016 at 5:29:09 PM
Standing Seam on a barrel vault roof
Tue, Jul 23, 2013 at 9:06:22 AM
Page generation time: 0.4728
