Forums >> General Discussion >> Revit Project Management >> Demo Door Leaf not Frame
Thu, Nov 15, 2012 at 8:47:00 AM | Demo Door Leaf not Frame
AlbrechtImaging
Hey everyone, I'm wondering if it's possible to create a door family that has the ability for me to set the door leaf to a demo layer while the frame is not.  We're replacing the door itself in some instances and replacing the entire door and frame in others and I was hoping to make a family that allows me the flexibility of that option.  I have experience making families and I know you can't attach a parameter to phasing which is unfortunate, but maybe someone knows of a work around that won't require me to go through and graphically override the appearance of all my doors individually.  Thanks!
Thu, Nov 15, 2012 at 9:03:43 AM | Demo Door Leaf not Frame
Why?
I would just do this as 2D and use the linework tool to show the door dashed as demo or invisible where you don't want to see it.
There is a point where it doesn't need to be modeled.
Thu, Nov 15, 2012 at 9:15:34 AM | Demo Door Leaf not Frame
AlbrechtImaging
That's what I'm currently doing, just wasn't sure if there was a way to imbed the option into the door family itself for use around the office on future projects.  I'll just keep going with what I've got then, thanks!
Thu, Nov 15, 2012 at 9:31:09 AM | Demo Door Leaf not Frame
You could make a family with some sort of switch but.....I would not.
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:46 AM
Demo door but not the frame
Fri, Aug 17, 2012 at 8:21:08 AM
Door w/ unequal leaf
Tue, Nov 27, 2012 at 11:08:37 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
door frame off-set
Wed, Mar 11, 2015 at 7:42:20 AM
Page generation time: 0.5902
